Zum Hauptinhalt wechseln
Die dritte Generation des Pixel, die von Google im Oktober 2018 veröffentlicht wurde.
Adhesive for camera and fingerprint when repairing back panel?
Just wondering aside from getting a new back panel and the adhesive for it … what would i need to properly get the camera lens and fingerprint scanner installed on the replacement back cover? This is my first repair so I am just making sure I’ve covered everything I need.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Definitely avoid super glue for starters. If you buy the black Tesa tape it should work just fine. Sometimes you can find the precut strips for components if not you can by a roll of the stuff and kinda make your own.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
So I'd still lose the water proofing that the device originally had with that. Am i wrong?
von
Yes. If you break the screen or back glass, you've already broken the water resistant seal. Although you can sometimes find the pre-cut adhesive, it may not match the OEM quality and in some cases, you need a special machine to check the seal.
von
Antwort hinzufügen
Miguel Rivera wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 725
