What year model parts are interchangable with an 2004 Chevrolet Tahoe
What year model parts are interchangeable with an 04 Chevrolet Tahoe 4 wheel drive 5.3 L engine
Ist dies eine gute Frage?
The Chevrolet Tahoe (and its rebadged version GMC Yukon) is a full-size SUV from General Motors. Chevrolet and GMC sold two different-sized SUVs under their Blazer/Jimmy model names through the early 1990s.
Rep: 1
James McNeill to list all the parts that are interchangeable would be a tall order. We could probably provide you with an answer for a specific part but not for all of them. For that I would recommend that you try to get your hands on a Hollander Interchangeable Manual.
Kommentare:
I have this question as well and let me see if I can ask it differently to get the answer that may help better.
What years match basically on a Tahoe Z71? Like 2003- or something like that. Matching down to specifics is ideal when you get there but examples would be a cluster, dash controls, window motors, seats, 5.3 motor and tranneys that would match up.
von Sonia Thibodeau
2004 Chevy Tahoe was badged as a GMC Yukon with the mechanical parts being the same. The difference in the 2 was in the trim lines with the Tahoe having more variations on interior & exterior options. Mud Guards, Upholstery, Radio Upgrades, and the like.
Without knowing what you want to check, the best we can do is give you an idea. For mechanical parts like the engine, drivetrain and parts like the radiator, GM reuses these parts like this across multiple vehicles - including engines, so for mechanical parts it (generally) isn’t as much of an issue to use parts from a similarly aged Silverado 1500, for example. The differences tend to be on the interior and body parts, especially in collision repair. You can’t use Silverado front fenders on a Tahoe or vice versa as those are unique to each model. As long as the engine codes match exactly, you’re probably okay unless you have a ZR1 or an SS, which would have a different stock tune then a standard V8 engine. The engine code is usually slightly different as a red flag, but if you see the engine came from an SS look elsewhere to be sure.
Emissions/exhaust parts tend to be a question mark as well. If your exhaust manifold has an issue and you find can’t find the Tahoe one, you may be able to pull one off of a Silverado 1500 and make it work. However, you need to be absolutely sure and match the part# against the original for exhaust/emissions parts. The interchangability on emissions hardware is not as good as other parts, as it tends to be tweaked for every model since there may be enough of a difference that the Silverado part *fits* but it allows for more emissions then the original Tahoe part. The emissions system is NOT fault tolerant and in an inspection state, that may be a legal issue when inspection time comes.
For OEM radios (pre-2007), they’re used as the immobilizer system and are VIN paired to the vehicle. GM could have used anything else like the ECU or put a dedicated module in, but used the radio. You can swap them if it’s electrically compatible, but you need to have those reprogrammed. On this, it would be done with a GM Tech II (1996-present). You can take it to a dealer and give them your VIN#, but they may charge you more then you paid for the radio just for 10 minutes of work. Try and find someone who can do it independently if at all possible for radios.
Rep: 1
I have a 2004 Chevy Tahoe z71 and I’m in the process of buying a complete upper intake manifold from eBay will a 2005-2006 upper intake manifold fit my 2004 ?please help me out !!
Letzten 24 Stunden: 41
Letzten 7 Tage: 331
Letzten 30 Tage: 1,268
Insgesamt: 5,050
Can I add to this and ask will a 2005 4x4 tahoe with a 5.3 be a match to a 2000 tahoe 4x4 with a 5.3 i want to pull the whole brake system rear end motor trans and some body parts from the 05 for my 2000 i should be good right? I know motor and trans are
von Brandon Luse
