Touch Not Working after Digitizer & FPC Connector Replacement
I’ve got an iPad Mini 3 WiFi (A1599) that belongs to a friend of mine that I'm working on. A few months back they dropped the iPad and it cracked the digitizer in the top right corner by the power button. They asked if I would repair it which I agreed to do. I replaced the digitizer and all was well.
A couple weeks ago they called and told me that the Digitizer was starting to lift in one of the corners. I told them no big deal and that I would re-tape the digitizer. This was partially my fault as I should have re-taped the replacement digitizer with my Tesa tape when I originally installed it, instead of leaving the garbage adhesive that came on the digitizer. But I despise working on iPads and just wanted to get it back together and off my workbench as quickly as possible. =p
So I got the iPad a couple days ago and disassembled so that I could remove and clean the old adhesive. I applied some new adhesive and proceeded to test fit the LCD & digitizer so that I could do a final test before final re-assembly. At this point I booted up the iPad and noticed that the Touch wasn't working. The Home Button and everything else was fine, but the digitizer was not responding to touch. So I attempted to re-seat the digitizer connecter when I noticed that a couple of the contacts were missing from the Digitizer FPC Connector. I replaced the FPC connector with a new one, booted up the iPad but still, No Touch! I swapped the digitizer with another one I had lying around but still, No Touch!. I also checked each leg on the FPC Connector with my multi-meter, and each one is making contact with the pads on the board, so I’ve ruled that out also.
I've never come across this issue before and was wondering what else I can check and/or replace to get the touch working again. Perhaps an IC or filter that maybe got shorted out when the FPC connector pins came loose?
Thanks in advance.
Ist dies eine gute Frage?
