Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1622 Fragen Alle anzeigen
Why is my laptop suddenly so slow?
I have a MacBook Pro 13in mid 2012, I have 16GB RAM and 240 FB SSD in currently. Everything was working great until a few weeks ago, it’s suddenly slow and has difficulty opening any pages! Is this an issue with my wi-fi router or my laptop?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
The most likely cause is a damaged hard drive I/R cable. here’s how to replace it:
MacBook Pro (13 Zoll, Mitte 2012, Unibody) Festplattenkabel austauschen
Here’s how to protect it:
War diese Antwort hilfreich?
Bewertung 1
Surprisingly you have a bad HD SATA cable! You’ll need to replace it MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable and here’s the needed guide MacBook Pro (13 Zoll, Mitte 2012, Unibody) Festplattenkabel austauschen. You’ll want to place a strip of electricians tape on the uppercase where the cable crosses Your Hard Drive Cable Is A Ticking Time Bomb.
You also need to be careful with the cable when you put it in. A common issue is people crease the cable at the needed bend points which damages it! You need to create a radius bend to do this you’ll need something to help you form it like a BIC ballpoint pen ink straw (empty). Use it to help form the bend at the corners.
The last issue is fixing the buildup damage on your drive. Backup your drive using TimeMachine and make a USB thumb drive bootable OS installer so you can reformat the drive and install a fresh copy of the macOS. Then using the migration assistant restore your stuff from the backup. Done!
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Bild
Produkt
$34.99
Bewertung 0
Here’s something worth looking at: if you open Utilities > Activity Monitor and look at the processes that are going on in the background, do you see anything using a lot of CPU (over 100%)?
I’ve run into issues like this and found it to be anything from a corrupted OS to a bad thermal sensor to a bad battery. Anything that the system interprets as a behavior that puts the hardware at risk will engage a process that throttles the CPU and causes very slow behavior…
Bewertung 0
Antwort hinzufügen
Tierra Nauman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 79
