Zum Hauptinhalt wechseln
Do I Have A Sealed System Issue?
My 10 yo French door refrigerator won’t get colder than ~42 degrees in either the fridge or freezer. All of the onboard electronic diagnostic checks come out good, the coils under the unit are clean, both fans are running, and the condenser is running an warm (not hot). But, the evap coils are frozen on the top right 1/4 and clean and dry else-wear, and there appears to be dried green sludge inside the backside of the unit. (See pics). What are the odds this is a sealed system issue and I need a new unit?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
@ladytech One for you.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Drew, you are correct. You have some erosion that has leaked the refrigerant. You definitely have an issues in the sealed system. The frost pattern tells me it’s low on refrigerant.
The leak can be repaired. I charge a minimum of $350 to repair a leak in the sealed system. Some companies charge a lot more. The repairs must be done by a qualified refrigeration technician per the EPA guidelines.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Drew Hilton wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 34
Insgesamt: 2,665
