Zum Hauptinhalt wechseln
Reparaturinformationen und -anleitungen für die lang ersehnte Neuauflage des beliebten MacBook Air, ausgestattet mit Intels Core i5-Prozessoren, einem aktualisierten Retina-Display und zahlreichen weiteren Änderungen und Updates, veröffentlicht am 7. November 2018.
Keyboard, membrane, dust/debris - What should I do?
I have noticed that there is dust/debris underneath my keys. Some of the silicone membrane is torn as well. Is there any way for me to clean my keyboard without opening up the device? Also, am I in trouble given the torn silicone? I am not experiencing sticky keys or any other keyboard issues, but would like to avoid such issues going forward. Thank you.
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
@tomchai Any advice?
von
@taylord Any advice?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Emily,
With these newer MacBooks, the keyboards can sometimes be very problematic. The best way to clean the underside of the keys is to use a can of compressed air. You can buy some at Staples, Office Depot, Best Buy, Target, Amazon, etc.
To clean the keyboard, you will want to follow Apple’s guide: https://support.apple.com/en-us/HT205662
Hope this helps!
-Alex
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hi Emily! Like Alex said, compressed air is the safest, easiest way to clean the butterfly keyboards. If you have a particularly debris-stricken key you can very carefully pry it up from the upper edge to remove the keycap before blasting it with air. I would only recommend that as a last resort though, since the clips holding the keys in place are very fragile so you may end up with a broken key unless you're extremely careful. :(
von
Antwort hinzufügen
Emily wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 28
Insgesamt: 2,031
