Zum Hauptinhalt wechseln
Das März 2015 Update von Apples 11" MacBook Air enthält Intel Core i5 und i7 Prozessoren der 5. Generation, was die Leistung und die Akkulaufzeit etwas verbessert.
My power adaptor, occasionally, stops charging the laptop.
11” macbook air, 2015. The power adaptor occasionally stops charging. Battery goes flat. Needs a lot of wiggling of the connector into the laptop to get it to start charging again. The orange and or green lights can be on, but the laptop isn’t charging.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Commonly one would think they have a bad cord. But since you indicated you have to wiggle in the connection that would suggest that you either have some dirt or something in the connection, the end of the power cord itself was bad but I would moreso believe the connection inside the laptop was loose or broke a solder connection. Check the cord with a voltmeter while wiggling it to see if your voltage goes off and on to confirm. Inspect connection they do often collect dust. You’ll have to open up the laptop to see if you have a broken solder point or if the connection is loose.
War diese Antwort hilfreich?
Bewertung 2
Follow this Apple T/N Apple Portables: Troubleshooting MagSafe adapters.
You may need a new charger do make sure you get a real Apple unit OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Within your system is the DC-In board, in this series its part of the I/O board if the contacts look bad I would recommend replacing it MacBook Air 11" (Mid 2013-Early 2015) I/O Board and here’s the guide to put it in MacBook Air 11" Anfang 2015 I/O Karte austauschen
Replace an I/O board compatible with the Mid 2013 to Early 2015 MacBook Air 11 inch laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe 2 power, USB, and audio ports. Bild
Produkt
$39.99
Bewertung 2
1 Kommentar:
This would be the easiest and best way to eliminate the issue altogether. Nice of you to present some helpful tutorials Dan. Score one for you..
von
Antwort hinzufügen
Jenny wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 312
