Zum Hauptinhalt wechseln
Won't run off power adapter, but charging light is orange?
My iBook sat for a few months and completely drained the battery. It won't turn on, regardless if it is plugged in. No power/lights/signs of life.
I bought a new battery that came with a half-charge, and the computer will boot-up normally with that installed.
The power adapter light is always orange, even if there is no battery in the computer. The battery does not get charged, nor does the OS show that it is getting charged.
Based upon research, I suspect it is the power adapter, except that the light is orange. The diagnosing steps state that the charging light stays green if it is a bad power adapter.
Thanks for your help.
-Cory
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Use a multimeter to test the output of the adapter. Check the tip of the adapter to see if it is broken. This may be the adapter or the DC-IN board. Download and run Coconut battery to see what you are getting. Let us know your results of both tests.
http://www.coconut-flavour.com/
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I'm not sure exactly how to test the adapter, and whether I'm testing Voltage, Amperage or Resistance. The center pole as 3 separate conductors, and the outer ring, which makes 4 probe points.
Assuming you're suggesting I test Voltage (while the adapter is not plugged into the computer), if I probe the bottom conductor on the center pole and probe the outside ring, the charge light goes Green and reads ~21 V.
I'm not able to make any other combination of probes read any results.
Regarding CoconutBattery, I'm still on 10.3.9, which doesn't appear to have a compatible version of CoconutBattery available. Is there another app I should try, or can you tell me what specific result you're looking for, that I could find in another app?
Thanks Mayer for your help.
-Cory
von
UPDATE - here's the pinout, it should be at 24 volts: http://pinouts.ru/Power/apple_tibookpowe...
von
I was able to borrow another Apple power adapter, and this proved to solve the problem. The computer will run off the power adapter, as well as charge the battery.
-Cory
Bewertung 0
my ibook4 adapter connect to it but charging start and adapter showing orange light .pls define orange light ? and green light ?
Bewertung 0
Different problem. This iBook G4 had been running, went to sleep and then power went from Green to Amber. Did not wake from sleep. Battery still show a full charge, but the iBook will not boot. No tone, nothing. Not on Battery nor on power alone.
Odd for it to die while in use.
Open to all suggestions on what to try next.
Bewertung 0
Antwort hinzufügen
Cory Sytsma wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 1,655
