Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Veröffentlicht am 21. September 2018. Modelle A1921, A2101, A2102, A2104. Erhältlich als GSM oder CDMA / eSIM oder dual-SIM / 64, 256 oder 512 GB / Silber, Gold oder Space Grau (Ausgesprochen "iPhone 10s.")
137 Fragen Alle anzeigen
What work do I need done?
On my screen, at the bottom right corner there’s a black splotch/blob. It started small and slowly is growing, and now my phone has the ghost touch. Whenever I try to type it’ll start pressing all over the screen. What will fix it? And how much will it cost? Are stores even open now for it to get repaired, due to the coronavirus?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
2 Antworten
broken oled you will need to replace the display on an xs max is can get pricey i would just call around to the local repair shops they should still be open (at least around my area they are )
War diese Antwort hilfreich?
Bewertung 0
Hi Denise,
Sounds like your display is faulty, depending on when you purchased the device you may still be under warranty. First step would be to visit apple.com/support and check warranty status. If there’s no other damage to it it may well be covered and they can walk you through the process.
If not you can get it fixed through Apple if you’d like at a cost. It varies between countries a little but visiting https://support.apple.com/iphone/repair/... should give you some idea.
Given that we’re on iFixit, if you’re confident with electronics repair / can follow the guides and want to give it a go. check out https://www.ifixit.com/Store/iPhone/iPho... It sounds like a screen replacement would sort the issue.
Hope this helps!!
Bewertung 0
Antwort hinzufügen
Denise Nguimdoh wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 32
