Zum Hauptinhalt wechseln
2,5 GHz Dual-Core Intel Core i5 Prozessor (Turbo Boost bis zu 3,1 GHz) mit 3 MB geteiltem L3 Cache.
265 Fragen Alle anzeigen
2012 retina 13” MacBook Pro will not turn on or charge
I am trying to fix a Late 2012 MacBook Pro 13” retina that will not turn on with the power button, and the MagSafe charger does not light up. I have tried the charger with another MacBook and it works fine and I tried another charger and the MacBook will not charge. I tried resetting the SMC with no results. I took off the back of the computer and found a water damage indicator that was red on the MagSafe DC board but no other water damage indicator was tripped. Should I replace the MagSafe DC board?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Yes, change the DC board—you may still encounter other damages to board due to the water damage.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Aydan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 44
