Zum Hauptinhalt wechseln
Apples iPad Mini Tablet wurde im März 2019 aufgefrischt und mit einem A12 Bionic SoC ausgestattet, das True Tone Retina Display erfuhr ein Update mit Unterstützung des Pencils.
32 Fragen Alle anzeigen
My ipad mini 5 bought in March 2020... Just a month old... doesn't c
My ipad mini 5 bought in March 2020... Just a month old... doesn't charges above 80%when charged in afternoon... In morning I use all 100%... Then I charge at 4.. to 5 pm in the evening ... But it only charges to 80%and doesn't charges above 80% ...
But in early morning when I charge it charges 100%...
Why is it so that it charges 100% early morning
and
'doesn't charges above 80% in the evening time...''
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
This is a battery management feature designed to extend the life of the battery. Keeping the battery charged to 100% 24 hours/day apparently chemically damages the battery. iOS will determine your typical use pattern and is supposed to only charge to 100% in anticipation of your use. Since you don’t use it at night, charge is limited to 80%; then, when your anticipated high-use time approaches it charges to 100% You used to be able to disable this feature; I just checked my iPad Mini5 under iOS 14.2 and that’s no longer an option.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Hiren wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 66
