Zum Hauptinhalt wechseln
Released in January of 2020, the Dell XPS 13 9300 is physically very similar to previous models but has optional upgrades for graphics and the processor.
9 Fragen Alle anzeigen
Screwdriver for Philips M1.2x2 screw?
Hi there,
My LCD screen on the XPS 13 9300 got damaged and I am looking to get a replacement for Dell. The screen replacement process seems easy enough so I thought I could do the re-assembly myself and save on labour cost (plus with the current situation, it’s kinda difficult to obtain service anyway.
There are three screws, however, which seem to be Philips type screws measuring 1.2mm in diameter. It is listed here: https://www.dell.com/support/manuals/sg/... as the “Display-assembly cable holder”.
May I know which Philips screwdriver would be most appropriate for this? I saw that there are #000 and #00 out there but they seem to be for 1.5mm and 2mm heads? Would like to avoid stripping the screw if possible (the user guide already adds a caution to avoid torquing the screw too much—I’m guessing it’s a really fragile screw).
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hi Reuben,
Where did you order a replacement screen for your Dell XPS 13?
I can’t find any good website.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @trenzterra ,
Here’s a link that may help.
I think that a PH00 would be OK to use for 1.2mm when you look at the point size
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Thanks! I am slightly confused though. The #00 seems to have several shank diameters from 1.2mm to 2mm. Why is this so?
von
@trenzterra ,
I assume that this is the sizes that this manufacturer makes for their driver "bits".
It may be that they might be sized if the screws are to be recessed in a slot and you need the bit diameter to be correct to fit into the slot.The diameter of the shank may differ but the point size is always the same PH00
This is just a a guess on my part though.
I've always gone for the point size as this is what fits into the screwhead., so perhaps PH0 might do as well
von
I see. Thanks so much! Will try a PH00 first.
von
Antwort hinzufügen
Reuben wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 684
