Zum Hauptinhalt wechseln
Acer Aspire V5-473P-5602 is a 14" Full HD touchscreen notebook originally manufactured in 2014.
1 Fragen Alle anzeigen
I need a base case for acer aspire v5 473
Where can I purchase a case base for this model?
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare:
Which country are you in... look for eBay
von
Yes, I’ve been searching EBay no luck Thank you
von
Einen Kommentar hinzufügen
1 Antwort
Hi @jsmalls24 ,
Do you have the old base case still?
There are a lot of base cases available for a V5 471 and V5 472 models which appear to use the same case, going by the part number.
If you have the old case still, check if there is a part number on it somewhere and then search online using the part number rather than the laptop model number.
It may be that it is the same case that is used for a different model but it is not listed for your model by the seller.
Just a thought.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thank you, I will check into that
von
I'm having the same issue. Did you have any luck with the 471/472?
von
Antwort hinzufügen
jeremy Smalls wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 260
