Replaced battery in applewatch series 2 and now is bootlooping.
I have an apple watch series 2 38mm that had a draining battery so I decided to replace the battery in it.
After the battery replacement the device is now bootlooping.
After ordering another battery thinking it was this and checking the old battery to see if that would power it up it is still stuck on bootloop.
I have also tried to do a hard reset to see if that will work (holding both the button and crown down) but this method is not working.
I’m currently at a loss and causing a bit of a headache. Does anyone have any advice or solutions to this issue? If so thank you in advance!
Ist dies eine gute Frage?
check the voltage on the new battery, if it's too low, it won't turn on or charge inside the apple watch, you would need to charge the new battery with a DC power supply
von Robert G
