Why won't tv respond ever since using fire stick?
My tv worked fine before using the fire stick. After plugging in the fire stick to the tv, I can no longer turn off the tv using either the fire stick remote or the original tv remote. The original tv remote no longer does anything now that the fire stick has been used on it that I can tell. Also, there is no way for me adjust volume on either of the remotes. The only way I can get the screen to go blank now is to put the fire stick in sleep mode. There is no way for me to change video output from a different hdmi port on my tv. Before, I’d use the original tv remote to hit the input button and select which hdmi port I wanted to view from but now that the original tv remote isn’t responding, the only way I can view something other than the fire stick is to unplug the fire stick and plug whatever device I want to use into the port that the fire stick was plugged into. And I’m really afraid that now that I can no longer physically turn off the tv, what happens if the tv does turn off due to a brown out or something? Will I even be able to get the tv to turn back on at that point? Since none of my remotes can turn the tv on or off now? Help!
Ist dies eine gute Frage?
