Zum Hauptinhalt wechseln
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
Component for the Power inside
Does anyone have the part number and location to purchase the receptacle on the board where the dc power plug plugs into..? I think the male pin is gone so I cannot charge it anymore…
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @chriscjpro ,
Here’s a supplier that shows the part numbers for the DC jack. (uncheck All and select DC Jack)
There are 3 types available according to the part numbers. There are also alternatives available as well.
When searching online using the part number for 1st available part in the list (12014-00104900) most suppliers stated currently not available and also they had no image of the part itself.
Searching for the 2nd in the list (12014-00102700) gave this result
Searching for the 3rd in the list (12014-00105100) gave this result.
The above is only to give you some idea of what they look like and the cost.
I don’t know your laptop and I’m wondering why there are 3 different types of DC jacks in that there are 3 different part numbers.
Maybe if you contact the supplier in the first link at the top they may be able to clarify this for you so that you can get the correct one.
Hopefully a start.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Chris Thomas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 147
