Zum Hauptinhalt wechseln
Model A1213 / 8, 16, or 32 GB capacity
283 Fragen Alle anzeigen
What a component is missing on the logic board iPod Touch 1st?
On the logic board damaged one component. I suppose it was resistor. What is it and what is its value?
Thanks
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
According to my multimeter the (missing red circled) component in the middle is most likely a resistor of 0 Ohms. The components in direct neighbarship left/right are 3.8kOhms resistors. The use of 0 Ohms resistors is not unusual in smd designs - often used as bridge or fuse (which might also explain why this component is gone).
War diese Antwort hilfreich?
Punktzahl 1
Kommentare:
Hello Chris. Thank you for your answer. In my device without this element resistance between two points of soldering is 0.0 ohms. It's strange, but looks like that this element is not needed.
von
Antwort hinzufügen
Alex D wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 640
