Zum Hauptinhalt wechseln
Dell Inspiron 9100 laptop with double row rear connections and 15.4 inch screen
3 Fragen Alle anzeigen
Frage geschlossen
How do you remove a hard drive & battery?
how do you remove the hard drive & battery from a dell inspiron 9100 laptop ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
This question was migrated from http://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Here is a link to the service manual for your computer. Use the" before you begin" for info on removing the battery. Good luck.
http://support.dell.com/support/edocs/sy...
War diese Antwort hilfreich?
Bewertung 2
Soft ware reboot
Bewertung 0
No
Bewertung 0
Battery is easy to un-clip. Turn over your laptop and you will see a lock at one side of battery all you need to is just to slide that downwards and pull the battery upward.
For take the hard drive off it pretty easy, have a look at sound card side your will see a screw at the bottom, all you need to do is to open that screw and pull the separate part outward it shall bring your hard drive off.
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,819
