Zum Hauptinhalt wechseln
A real test for you guys, gas cart won’t start
Howdy, do I recently got a 2016 club cart precident. And I ran into problems because it wouldn’t start. The battery is good but when I press the gas nothing happened. So I replaced all suspect parts, solenoid, carb, micro switch, fuses, I even replaced the gas petal. I made a little progress because now there is a clicking when I press gas but other than that it won’t start. Any ideas?
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
This question was migrated from https://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
2 Antworten
when u say u pressed the gas what do u mean, like did the rev get higher and nothing moved or when u press it, it stays at idle?
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
When I press it nothing happens like at all, no noise no nothing
von
We have this issue at work a-lot but the main issue that we found is that the gas pump does not have the suction to pull the gas from the tank so there should be a little clear fuel filter if there is no gasoline in that filter then that might be your problem.
Bewertung 0
Antwort hinzufügen
John r wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 13
