Zum Hauptinhalt wechseln
A1418 | EMC 2889 | Ende 2015 | 1,6 GHz Dual-Core Intel Core i5 oder 2,8 GHz Quad-Core Intel Core i5. Erscheinungsdatum 13. Oktober 2015.
47 Fragen Alle anzeigen
iMac Right audio output has crackling noise when using headphone jack
Hi,
the right audio output has the crackling noise whenever I use the headphone jack for any external devices. Does it affect the computer if I don’t fix it? and what should I do in order to solve the problem?
Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
ccz827 sounds like a bad jack. What should I do in order to solve the problem? It is soldered to your logic board so unless you are planning to replace it by resoldering a new jack, I would suggest considering an external USB device to eliminate that. Does it affect the computer if I don’t fix it? No, it will not aadversely affect your device.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Hey oldturkey03, I've almost always found that when audio things get "static...E" sound like that, it's almost always a bad grounding on either the jack or plug end. Usually the jack end since it gets most abuse and the ground wire gets loose. Cheers Bud, Stay Safe!
von
Antwort hinzufügen
ccz827 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 208
