Zum Hauptinhalt wechseln
Modell A2159, EMC 3301. Eine Neuauflage des Einstiegsmodells des MacBook Pro. Erhältlich in Silver und Space Gray. Erschienen im Juli 2019.
110 Fragen Alle anzeigen
The fan is too loud and the laptop get very hot.
Even so, that i am not doing something heavy on it like playing games or something.
It happens even when i am browsing through safari or just working on some word files
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
What is the size of your drive and how full is it?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
My first thought is that you have a program running that is putting your CPU usage at a very high level. See if you can run a resource monitor to show you what is using your components so heavily.
If you keep the laptop in a dusty location or use it on a blanket that can allow fuzz to enter the fans then they could be clogged preventing proper cooling. Follow the guides on this site to show you how to take apart the laptop so that you can clean the fans and air intake ports.
If the resource monitor really high CPU temps you may need to reapply thermal paste to the chip. Again follow guides on here.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I would add don't use your system on top of your bed or rug as they also block the vents air flow.
How about also installing a good thermal management app like TG Pro it will help narrow down whats getting hot. And if need be allow you to push the fans when the temp gets too high (turbo).
von
Antwort hinzufügen
Abdullah alhindasi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 52
