Zum Hauptinhalt wechseln
Vierte iPad Generation, erhältlich seit dem 2. November 2012 mit 16, 32 oder 64 GB Speicherkapazität. Modellnummerb A1458.
218 Fragen Alle anzeigen
A dead little thing on iPad 4's motherboard
Hi, my iPad 4 is not turning on but when i plug it to the macbook it sees my iPad. So i thought it’s the screen and I replaced it but nothing happened. I checked the motherboard and saw a little thing is damaged i think. What is it and is it repairable? Thanks. https://ibb.co/b6h8vfz
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It looks like a burnt diode or resistor. You will need someone who does micrsoldering to repair it. You can get the part from a donor board or order the parts online.
Update (06/01/2020)
I would practice on dead boards and watch quite a few videos from jessa at iPad rehab ipadrehab.com and Jason at sts telecom ststelecom.com both have YouTube channels. You can pick up and entry level soldering station on Amazon. I would recommend the hakko fx 888d or if you want to go professional hakko fx951. Make sure to get a exhaust fan. They sell them on Amazon. You can also pick up practice boards to get your skills up. They cost about 5 to 10 dollars. It would also help if you have a microscope. I don't know if you are interested in doing this for a job and are just starting out. But if you are just doing this as a hobby. I hope this helps you.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks a lot. And do u think that a beginner can make it?
von
Antwort hinzufügen
Okan E wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 40
