Zum Hauptinhalt wechseln
Dokumentation und Anleitungen für die Reparatur des am 22. September 2017 veröffentlichten iPhone 8. Modellnummern A1863, A1905.
872 Fragen Alle anzeigen
weird iPhone 8 power problem
my iphone 8 has a weird power problem where it won’t turn on with the side button or a charger plugged in but i can put in dfu mode and itunes recognizes it but it won’t restore because it never reconnects after itunes kicks it out of dfu mode. is this fixable cause i’m stumped
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This sounds like a NAND or CPU problem. When it exits out of DFU mode it is not getting instructions on what to do next that’s why it never reconnects to iTunes. The only thing I would try is replacing the battery as DFU mode doesn’t use much power so when it switches from that to normal mode if the battery was faulty and couldn’t supply enough amps it would shut down.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
letting it die and then plugging it in caused the low battery symbol to come on the screen followed by the apple logo which disappeared after a few seconds and i was back to the original issue
von
I would definitely replace the battery
von
So the battery may be bad
von
Yes. You need to rule that out first.
von
Antwort hinzufügen
Cheap gamer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 71
