Zum Hauptinhalt wechseln
Die Wii Remote ist der originale Controller für die am 19. November 2006 veröffentliche Spielekonsole Nintendo Wii. Die originale Wii Remote hat die Modellnummer RVL-003.
My Wii Remote is draining the batteries way too fast.
Hi, community of iFixit! So I’ve got a strange problem with one of my Wii Remotes. One of them is draining the battery surprisingly fast (about 10 minutes from full to flat). The weird thing is that the problem is not with the batteries since I’ve tried many different types, but they are still going flat extremely fast in this Wii Remote. If I put in really powerful batteries, I’m probably getting about 20 minutes more of battery life… But still!
I’m not sure if there is some short circuit in the motherboard in the remote or not, but as far as I’ve understood (by Google) the batteries should begin to go flat after around 30 hours of gameplay. Not 10-30 minutes.
The remote is old, yes. But this is still a weird behaviour. Have anyone got any solution or thought of what could cause this short battery life?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
If your Nintendo Wii Remote is having battery issues, use this Nintendo Wii Remote Won’t Turn On problem page for possible causes and solutions.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
That did not help at all. The question posed described the problem well. The remote works fine, but battery life is abysmal. The linked page only has solutions for the remote not turning on. Did you read the question before answering?
von
I'm having exactly the same problem, have you found a solution?
von
I have the same issue. I have a black motionplus wiimote. Rvl-036.
von
I have this problem on two Wii remotes. Full to that in mere minutes. I'm not seeing much online except that this is a common problem. Could it be a faulty capacitor in the remote?
von
Hello I fixed this issue with a q-tip with a couple drops of isopropyl alcohol. I rubbed all the battery contacts (even if none is visible) clean which includes inside the little spaces between and air dried the Wiimote for a couple minutes
After I let all the alcohol dry, I used the semi-fresh batteries that I thought the Wiimote drained and they worked again with the amount of life they shouldve had
So, if your Wiimote doesnt respond to batteries or blinks for a few seconds and dies in a minute or a second, this might be the issue and the fix for it
Bewertung 0
Antwort hinzufügen
Linus wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 36
Letzte 30 Tage: 178
Insgesamt: 8,095
