iPhone 6s battery to 7
Hello, do you think i can put iphone 6s battery to iphone 7? Because i have noticed today that my 7 battery is 78% so ive got a 6s battery with higher capacity, will it work? Thank you
Ist dies eine gute Frage?
No the connections are different. Every year they change the connections on the new models.
War diese Antwort hilfreich?
The iPhone 7 battery connector is 0.25mm shorter than iPhone 6s.
The iPhone 6s have the same connector as iPhones SE, 6+, 6S+, but they have different sizes of battery.
Battery from iPhone 7 fit to iPhone 6s but it is poor connection - I checked it only in Battery Programmer not on phone, so you do everything at your own risk.
But there is a solution to your problem. Yoy have to resolder battery flex from iP 6s to iP 7, but if you have no experience in such things, you better not touch anything.
Hi! The connections are the same per phone but if you do try to swap them the phone will react poorly and have terrible performance.
Connectors aren't the same!
Letzte 24 Stunden: 5
Letzte 7 Tage: 9
Letzte 30 Tage: 31
Insgesamt: 248
