After buying a new battery my Mac doesn’t want to turn on
I bought a new battery because the old worked only for 1 hour and capacity 65%. After the replacement I made PVRAM and SMC reset. Mac does not want to start without a charger. I turn on the charger and after that it works well, it shows that it is charging. When I turn off the charger at restart it comes to chime and turns off again. Also don't wake up from sleep mode. I restored the old battery and everything works perfectly. Is the new battery defective?
Update (06/12/2020)
This is the charging display:
Update (06/14/2020)
After I completely discharged the battery, I charged it all night (12 hours). Two times.
I give up because the situation remains the same, starting the device is not possible without a charger. I definitely returned the old battery and now everything works, only the autonomy is 1 hour.
Old original battery satus:
Ist dies eine gute Frage?
5 Kommentare
What is the color of the MagSafe chargers LED Amber or Green?
The CoconutBattery output shows me the battery is OK, but the charger is not charging it. Lets make sure the charger is connected and is charging.
I would inspect the MagSafe connections following this guide: Apple Portables: Troubleshooting MagSafe adapters
It's also possible the charger you have is a knockoff which has damaged your logic board.
von Dan
The charger charges correctly, he is original, undamaged, Amber lights up when charging, glows green when charged. So it was with the old battery. Coconout show's charging with 19,78 Wats.
von Alen Bajo
@abajo - I see Discharging at 20.79 Watts here. Not Charging!
The Power adapter is not connected.
von Dan
That was when the charger was not plugged in.
von Alen Bajo
@abajo - Now let it charge for a good eight hours, then test things again the battery at that point should be fully charged.
von Dan
