Zum Hauptinhalt wechseln
Ein tragbarer Bluetooth Lautsprecher, hergestellt von Ultimate Ears.
60 Fragen Alle anzeigen
Won't play without being plugged in
My UE Megaboom will only play when it’s plugged in.
It will flash like it is charging for around a minute then the light will go out and nothing happens. If I turn it on while plugged in, it will turn itself off after around 10 seconds unless I am running something through it. I have tried resetting and replacing the battery with the same results. The speakers crackle at high volumes but I am sure this issue is unrelated.
It would be a shame to throw this thing away because they are great when working properly.
The only thing I can think is that it is not charging because initially it was turning off and on every few seconds but now I also get the critical battery warning if I don’t play something through it. So the power must be getting through.
Any ideas????
thanks
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It could be a faulty motherboard or the charging chip, I dont really know much about these but just sharing my opinion.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jeff Cullen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 93
