Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
A2116 / 2019 / 3,6 GHz Quad-Core i3, 3,0 GHz 6-Core i5 oder 3,2 GHz 6-Core i7 Prozessor. Veröffentlicht am 19. März 2019.
39 Fragen Alle anzeigen
Upgradability of iMac 21.5 inch
I am planning to buy an iMac 21.5-inch Retina 4K but I would like to know how much upgradability there. I know that the RAM is upgradable up to 64GB. I am buying one with a 1TB Fusion Drive, but can I change this to an SSD after purchasing? Since Apple charges a lot for extra storage and RAM. Can I also upgrade the processor? It comes with a Core i5 but if it is possible I would like to upgrade to an i7 at minimum.
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
YES!! you can pretty much upgrade everything except the display
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
@ranger1509 - Please expand your answer! What are the drive options and limits as well as which CPU's are workable.
von
@ranger1509 - That is not correct! Intel CPU's have micro code loaded in the systems ROM. This microcode is unique per the chips series as an example here Coffee Lake: Intel Core i3 (8100), Core i5 (8500), or Core i7 (8700).
The other variable is the TDP can't be more than 65 W. So as an example a i9-9900K (Coffee Lake) is 95 W which won't work properly in this system as the power supply and cooling would not be able to support it.
What are the logic board I/O's for storage devices?
von
Antwort hinzufügen
Abel Benoie wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 7
Insgesamt: 121
