Zum Hauptinhalt wechseln
The LG Stylo 4 is a stylus-equipped midrange slate-format Android smartphone released by LG in 2018. Identifiable by model numbers L713DL and Q710(AL, CS, MS, TS, ULM, ULS, and US).
How do you fix 'moisture detected?'
Hello! I own a LG Stylo 4, and it hasnt been able to charge. It keeps saying moisture detected. This has happened before but turning it off and back on worked.. But now its dead so I cant charge it at all. Its been like this for over a month now.. Ive tried so many things, using a blowdryer to dry it out, ive tried charging it without the SM card, but it just wont work. Id get a wireless charger, but im not sure if there are any for my phone. Any solutions?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It’s a common issue for phones nowadays to not be able to charge after sometime.
This can be either some ‘‘pocket residue’’ that has accumulated over time in the charging socket (which your phone interprets as moisture), or the socket itself has been pushed further inside in the device.
If any of these is the case, you can have it serviced at a phone shop, usually with minimum or no charge (depending on where you live and company policy).
See Moisture Detected, Charging is blocked.. ,may be helpful
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Chelsi Hotz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 728
