Zum Hauptinhalt wechseln
Model A1224 / Mitte 2007 und Anfang 2008 / 2, 2.4, oder 2.66 GHz Core 2 Duo Prozessor
548 Fragen Alle anzeigen
iMac 2008 screen issue (not backlight)
I purchased a 2008 iMac and have a problem with the screen. The screen stays black but chime and fans start when pressing the on button. There is a light coming from the back of the screen which is how I know the backlight is working but there is nothing appearing on the screen.
can someone help me on ways to diagnose this problem? I am a newbie.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If you are seeing a white light glow around the screen then your backlight is working all you are seeing is the lights leakage! To prove that take a strong flashlight place it on the screen at a sharp angle the light aiming in would allow you to see a faint image of your desk top and its icons.
- If you see the desktop and its icons that would imply the backlight has failed.
The other test you can do is plug in an external display via the Mini-DVI connection on the back using the needed adapter to convert it to what ever your external display offers.
- If you don’t see an image that would imply your logic board has failed.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Chad wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 66
