Original Xbox drives are famously known for DRE issues sadly. I bought 2 for $40 and one of them had a bad drive from the beginning that just wouldn’t work, but the other one was fine (likely Phillips based on the tray). Thompson and Samsung SDG-605 -006 drives are known to have DRE issues more often the other drives used in these consoles. With the original Xbox, you can buy whatever drive you want since they are not paired and Live V1 has been dead since 2010, so if you have a SDG-605 -006 or Thompson it is advisable to buy the Phillips or Hitatchi drive. However, Hitachi drives are rare and expensive, while Phillips ones come at a premium but are easy to find. As far as the Samsungs go, do not bother with the SDG-605 unless you get a good price AND make sure it’s a -005 revision, since these are the better of the two Samsung models. However, these are hard (but not impossible to find) since they work with backup games so well and people drive swap modified consoles. If you need additional information, refer to this page for information on the DVD drives the original uses.
I did eventually repair the DRE console since I FINALLY found a reasonably priced drive (Phillips VAD6035/21), but it took a while due to the cost. If you have an urge to play it now, I'd find another console and check for a replacement drive on a regular basis.
If you know the minimum trimpot level and safe maximum (you will need to find this on your own), it is possible to trimpot the lasers to potentially get them to work again, but you need to have a multimeter and descent electronics experience. I’ve found people who do not know how to do it safely will ruin the laser and potentially a game or two in the process.
If you have a Samsung, me and @bulkchart32 had a discussion on trying to fix ours here: Which laser do I need? (Rev.A Samsung SDG-605). The information on this pertains to the SDG-605, so if you have another brand of drive this WILL NOT APPLY. Ultimately my original drive was unrepairable, but the information may still help you since you have nothing to lose, since Xbox shovelware testers are cheap.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
