Zum Hauptinhalt wechseln
A garage door opener is a motorized device that opens and closes garage doors and is controlled by switches on the garage wall.
Lights don’t go on when door is opened or closed
Lights don’t go on when garage door opens or closes
Update (07/20/2020)
Light bulbs are fine
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
You're going to have to get a multimeter and start tracing this problem. Ours have relays that click on and off and if yours does, but it doesn't click, there's where to start looking. If you're not good with 120 volts, don't touch it unless it's unplugged.
War diese Antwort hilfreich?
Bewertung 1
If it doesn't go on even when the light button is pushed, you may want to check the bulb first.
Bewertung 1
Antwort hinzufügen
Peter Provinzano wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 108
