Zum Hauptinhalt wechseln
Fix Maglite that doesn't work or works intermittently.
Why does my light go bright then dim and Bright then dim?
I want my to stop flickering bright ,dim ,bright, why? I just want it to work right.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Most likely there is some corrosion or loose connection. Follow the complete teardown instructions including the added comments. A q-tip with vinegar goes a long way when it comes to Maglites. You just need to take it apart completely including the DO NOT REMOVE tab and clean all the parts thoroughly. Good luck.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thank you I have no idea what I am doing
von
Just stay with me all the way
von
What do I need to do next
von
Antwort hinzufügen
Phil Chingon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 631
