Zum Hauptinhalt wechseln
Der iRobot Roomba 880 ist ein autonomer Staubsauger, der 2013 herausgebracht wurde und im Vergleich zu den Vorgängermodellen über mehr Leistung und bessere Reinigungseigenschaften verfügt.
roomba 880 rattling loudly
roomba 880 rattling loudly, on and off, on smooth floor. Can see no initiating factor.
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare:
So it is not moving and you hear a rattling sound and at the same time the iRobot is turning on and off itself?
von Teilen
@eke0909
The Roomba moves and vacuums, but it has a rattling noise as it vacuums that goes on and off and is worsening (noise going on and off not vacuum). The rattling is not associated with whether or not the circling brush is active. Sounds as if something is about to fail or fall off.
von Teilen
@scfonta
So you don't really know what part is moving when you hear the noise?
von Teilen
@eke0909 exactly. Can't tell and it turns off if you flip it upside down to look. Have done normal maintenance & checked screw on the whirly brush. Was hoping others had had similar issues and could tell me what it is before a part falls off!
von Teilen
Einen Kommentar hinzufügen
2 Antworten
Cause of the problem
My guess would be that a lot of dust and other debris has gotten stuck around something, which stops the part from spinning smoothly. It may also be that the debris has forced a part away from where it’s supposed to be.
I have another brand of a robot vacuum that I'm taking apart and cleaning now and it really needed cleaning, it didn’t have the same problem as yours but I found a few places where it looked like it would cause a similar problem anytime.
How to turn it upside down and it still runs
From my understanding, you should be able to turn it upside down by holding the wheels down, I think that’s the mechanism detecting if it’s on the floor or not.
How to solve it
If you feel comfortable with taking it apart and clean it from dust etc., that’s what I would begin with.
If you find what part it is that sounds bad and don’t want to clean the other moving parts when you're on it, you can go for just that one.
I found two guides on how to get to the Cleaning Head and Side Wheels, and this video should also help you.
If you found that a part looks weird/broken in the process of cleaning it, add a picture of it in your question and I or someone else can help you.
Hope this helped, feel free to ask if you wonder anything else and good luck. :D
iRobot Roomba 880 Reinigungskopf Bild
Anleitung
iRobot Roomba 880 Reinigungskopf austauschen
Schwierigkeitsgrad:
Leicht
5 - 10 minutes
iRobot Roomba 880 Seitenräder Bild
Anleitung
iRobot Roomba 880 Seitenräder austauschen
Schwierigkeitsgrad:
Leicht
4 - 7 minutes
War diese Antwort hilfreich?
Bewertung 0
The previous advice about thoroughly cleaning is good. My Roomba does have a broken part that causes this though.
I’m not sure the correct name but its the hollow hatch that goes over the rollers. It has broken near the middle on the side away from the hinges. If you get it in the right place before cleaning it works OK still though it can be put out of position if the Roomba goes over something it shouldn’t (a cable or something large).
Maybe worth checking on yours if nothing else helps. Sadly I can’t find a replacement part anywhere.
Bewertung 0
Antwort hinzufügen
s fontaine wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 4,814
