Zum Hauptinhalt wechseln
Reparaturanleitungen und Informationen zur Demontage des MacBook Pro 16", das im November 2019 auf den Markt kam.
96 Fragen Alle anzeigen
Screen backlight is on, but it's not showing anything
Hi, so I got this macbook in February, and I’ve come back to it today and tried to turn it on and it starts up with the screen, keyboard etc all lighting up. It flashes the Apple logo for a split second and then nothing, the screen stays on but is black. A tiny hairline crack has appeared at the top of the screen no bigger than half a cm. Don’t know how this has happened macbook was in the same place I left it less than a hour before.
I can also log into my account, which I can tell because the Touch Bar changes when you log in and I can find my way on to different programs like Chrome by random chance.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Ouch! You need a new display assembly! Time to find your way back to the Apple Store or authorized dealer/service center to get your system fixed.
I hope you are sitting down … This likely won’t be covered under warranty, so expect to pay for the labor and the replacement display, a new display goes for over $1000 USD!
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
Honestly though how can such a tiny crack stop the computer from showing anything even when it's running and the backlight is on. It seems suspicious to say the least.
von
A crack breaks the electrical pathways the display needs to turn on the discreet pixels.
It doesn't take much to break it! a paperclip resting on the uppercase when you close the lid is all it takes.
To prove it connect an external monitor, I think you'll find it will have no problems with it.
von
@danj still strange as I've had a monitor before that had cracks in it with a thick line and an area of dead pixel and it worked for another year before I could be bothered to buy one. On my old Macbook from 2015 this thing feels so much more robust.
von
@TobyO Graphics - Ah! Comparing older versions of display to this one! Not the same ;-{
The older displays had a cover glass and then the LCD panel. Todays display don't have this cover glass! Just the exposed LCD panel which is a sandwich. Compare these two systems display configs
MacBook Pro (15 Zoll, Ende 2008 und Anfang 2009, Unibody) LCD austauschen
MacBook Pro Retina Display Teardown
Do you see the differences?
Apple cut away even more space as the thiner the better in the TB models (Nope!)
von
Antwort hinzufügen
TobyO Graphics wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 53
