Phone restarts after replacing parts
Replaced iPhone 11 screen and front speakers and front camera and once i turned it I could use it for like 2 minutes before it turns off and on again. Why is that?
Ist dies eine gute Frage?
Reseat the battery connector and try. If it does the same start disconnecting the parts you replaced until you find what part is causing it to restart.
War diese Antwort hilfreich?
my iPhone 11 was water damaged. after open it into air for 2-3 days, it start to work. It screen is working fine but keep restarting after 2-4 minutes.
this issue is keep coming on my iPhone 11. I disconnected all parts one by one but it still keep restarts after 2-3 minutes. Any solution?
&&^& I have the same problem, I sent to few places and they say I have to change the motherboard
How we can buy and change new motherboard like screen? will that be original motherboard with all apps and Apple ID functions working?
Did you figure it out? check settings>privicy>analytics, it should tell you whats wrong, probably “thermalmonitord”
How we can use this information of analytics. I can see in my broken phone there are many files? can phone fix use this info for fixing the phone?
It is happening in my customer iPhone 11 also.
Did you find its solution?
I'm having same issue, suspecting either screen or battery
I have also an Iphone 11 after I replaced the screen and battery it keeps restarting even if I only connect screen and battery without the other flex cables.
I’m suspecting the screen I will buy a new Iphone 11 screen and a new battery to test.
Note I have tested another motherbaord and it keeps restarting.
And I’ve tested another battery and it keeps restarting
I have tested with Iphone xr screen and it keeps restarting
The only conclusion for me here is that I’ve been so unlucky and all those screens and batteries are faulty (or non compatible)
I will let you know if I find a solution.
same - restarts after 2-4 min. i did a complete restore to factory settings and reinstalled iOS. Took like 3 or 4 tries as it kept failing. Seemed to work for a few days, but now it’s restarting again. i suspect it is a bug. i usually NEVER HIT THOSE DOWNLOAD THIS links, but i was on youtube and i accidentally selected a link… it happened to be something that interested me so i did not immediately back out or closed app…or it could be poopy iphone component… but
Letzten 24 Stunden: 2
Letzten 7 Tage: 8
Letzten 30 Tage: 32
Insgesamt: 544
