Mic doesn't work after charging port replacement
I replaced my charging port with an iFixit replacement. After putting back together everything works as expected except for the mic when not on speaker phone. From my research, the mic is part of the charging assembly. I am wondering if I received a defective part? I am going to take apart again in check all connections. I’m wondering if anyone else has suggestions…
Thanks!
Ist dies eine gute Frage?
3 Kommentare
Hi. what was the solution for your problem ? have exactly the same problems…..
von kevin reiter
I did another charging port change and the mic works fine now. It's likely the board I received was defective since the connector seemed seated fine for the faulty board. I was able to perform an exchange to receive a new board. After installing the new board, everything works fine now
von SEAN BEAUSOLEIL
Ok thanks. I think i have the same problem. Ordered new board to test it.
von kevin reiter
