MacBook Pro (15-inch, 2018). display damage and water damage need help
Hello everybody,
Can someone please help me with my (MacBook Pro 2018) and the display broke when I closed the MacBook Pro and I also had water damage that came on top and now I have the following defects on the MacBook Pro (display damage, A USB-C connection, Touch ID, Bluetooth) these things no longer work and can someone help me and tell me how to repair it in the best and cheapest way? And most important of the things is that I get the display repaired and have already got it from (Ebay.de) and (aliexpress.com).
I looked for a new display but do not know whether I have chosen the right one and maybe someone can help me a bit and tell me which display I need exactly. On the picture (IMG_0415) you can see how the damage occurred and I closed the display while the cable was on the keyboard.
Update (23.08.2020)
I have one last question, is there a list where you can see in which (Macbook Pro 15 2018) a display from 2016. 2017. 2019 or older series can be installed ???? Because the displays are almost the same in terms of design and connections, or not?
Ist dies eine gute Frage?
3 Kommentare
von Andrej
@sauke - Sorry to tell you, you need to use the correct one.
Apple altered a few things even though they look alike (2016 thru 2019)!
The 2018 & 2019 are the same as they offer True Tone the older 2016 & 2017 have a cable issue and won't work correctly in your system.
The older 2015 display is a radically different design.
So... No substations possible!
von Dan
@danj Thank you very much you helped me a lot! And thank you very much for the information and your time! Stay healthy and be careful in this difficult time and Top Forum and thank you very much Dan!
von Andrej
