Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
13" Aluminium Unibody, 2,0 oder 2,4 GHz Core 2 Duo Prozessor.
675 Fragen Alle anzeigen
Screen doesn’t work proper: no backlight, with image
I recently replaced my display’s data cable in my MacBook, and now the display has an image, but no backlight. The image can be seen via light shone through the logo on the back of the lid, or by shining a light on the front. For some context I also recently replaced the thermal paste, which involved me removing the logic board, and led to a damaged data cable for the lcd.
My computer is a unibody MacBook from late 2008, 13”. Any help or leads on this would be appreciated, as I have put a lot of time into keeping this laptop working, and I rather like it as well.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
1 Antwort
This sounds like you damaged the LVDS connector on the logic board or the cable end is damaged. In turn the backlight logic on the logic board has become damaged too! Before fixing the logic board lets make sure the cable end and the connector are not damaged.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Walter Xavier wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 6
Insgesamt: 14
