Zum Hauptinhalt wechseln
Ein Mittelklasse-Smartphone von Samsung aus dem Jahr 2019
117 Fragen Alle anzeigen
white lines showing on screen after display replacement
I tried to replace display of Samsung A50 but I saw a huge white line on the screen and also a black area at the bottom of screen appeared. At first i thought new lcd has problem but I see same issues after replacing the new one with original lcd. Do you have any idea about this issue?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Ehsan Hosseini check the connector and make sure that all the pins are properly aligned and that they are not bend or broken. After that it will be an issue with your logic board. Check the components around the display connector. You can also post some good pictures of your circuit board (front and back) so that we can see what you see. Post those pictures with your QUESTION. Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Ehsan Hosseini wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 798
