water damaged 2019 MacBook Pro data recovery (t2 chip)
Hey,
I have the same problem. I have 2019 MacBook Pro 16 inch 512 gb (I think it has T2 chip), and it has been damaged by water unfortunately.
I took it to apple and they said they have to change the motherboard totally as CPU is broke (short circuit). but if they do change the motherboard , I will loose all of my data and files. can anyone help me if I can have my datas from my MacBook. ?
ps : My MacBook is not working at all.
Your help is highly appreciated.
Ist dies eine gute Frage?
Yes, your system uses a T2 chip to encrypt your storage.
von Dan
I have the Same model with water damage. My logic board works fine but my display won’t show images
von Miguel Hernandez
@Miguel Hernandez - If you still can log-in you should be able to connect a external drive and run TimeMachine to make a backup of your stuff. I would start there.
Time is agaist you! So don't waste it as the longer your system stays wet the worst it will be saving it. Even if its dried out now the dried spillage will damage your system over time.
von Dan
