Zum Hauptinhalt wechseln
Apple Watch Series 2, angekündigt am 7. September 2016 und veröffentlicht am 16. September 2016.
132 Fragen Alle anzeigen
I replaced the battery, but the screen now only displays 1 color (Red)
It appears that the LCD screen is only displaying red and missing green and blue from the RGB display, maybe something broken with the display connection? Anyone else had this issue?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hello there!
Probably the flex or connector on mo-bo is faulty. As far as I know Apple makes those parts very thin and fragile to avoid messing around by “unqualified personnel” (if only they would be qualified enough and not only using predesigned tools).
Check if the connection is proper for your LCD flex. Clean with IPA, check for bend pins and check if the connector is not bend itself during unplugging. Alternatively check on different screen.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Michael Selby wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 115
