Why is my LCD panel moving and touching erratically on its own?
Okay so this isn’t the first time I’ve replaced a digitizer on an iPad, however, this is the first time I’ve changed the digitizer on an IPad 7th generation. Before I changed the digitizer I check the iPad to see if it was working, it was but the digitizer was obviously cracked. So I took it apart no problem and removed the lcd in order to install the new digitizer, after installing the digitizer and reinstalling the lcd I tested the iPad by turning it on and now all of a sudden I have ghost touching issues and it’s really bad, even without the digitizer connected the screen move some it’s own. The whole screen is being moved on its own, opening up apps, typing, etc. I believed I did everything right and I even opened it up again to clean the contacts on the lcd cable to no avail, what can I do now?
Ist dies eine gute Frage?
1 Kommentar
I have the exact problem - I've tried 2 screens and 2 digitizers so far - still ghost touching so much i can't even pull up settings.
von Tre' Church
