MacBook Air screen is flickering and fading.
I think this video is self -explanatory.
Any idea?
Ist dies eine gute Frage?
Any idea?
You have a damaged LCD panel. There are a set of fragile connections from the LCD to the T-CON board which have been damaged. So as you move the display you are allowing the connections to make and break.
Here’s the needed part: MacBook Air 13" (Mid 2013-2017) Display Assembly and here’s the guide to put it in MacBook Air 13" Mid 2013 Display Einheit ersetzen
War diese Antwort hilfreich?
Thanks, could I replace only the T-CON board?
Replacing the T-CON board won't help you here (and you can't replace it alone and its not the T-CON bd its the ribbon cables between) You need the full assembly.
Hi I have a 2013 Macbook Air and the screen was flickering yesterday but today it is fine and then started again this evening I managed to put on airplay so I can still use it but the laptop screen is still flickering even though the picture on the airplay screen is fine. please could you help
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 131
