Zum Hauptinhalt wechseln
Die 7. Generation der Moto G-Reihe von Motorola. Dieses Smartphone wurde im März 2019 veröffentlicht und ist das erste Motorola Moto, das mit dem Betriebssystem Android 9 ausgeliefert wurde. Die Modellnummern sind XT1962-1, XT1962-4 und XT1962-5.
Removing Google Play Music from my phone?
While I knew Play Music was due to be shut down, I was hoping that it would still work as an offline music player, but Google has killed it off entirely. The issue at least with my phone, is that I got my one OS update and that means I can’t expect another update to remove Play Music from my phone unless Motorola does it as a minor OS upgrade.
Seeing as I’m probably stuck with Play Music on my phone since Motorola is not likely to remove it, is there anything I can do to remove it entirely from my device?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hi @nick ,
Found this which may be of interest.
Haven't got around to trying it myself yet, so don't know if it works or not.
Cheers
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There are two options available:
  1. Go to Settings, Apps, Google Play Music. You should have “Uninstall” available. Tap on that, it will ask you to confirm. Select YES, and that should be easiest way.
  2. Same steps as the before, however, if it states “Disable”, that on that, and it will reset the app to factory settings, purge the cache, data and update history.
Google is pushing updates to this app to be allowed to be uninstall, by making it not essential to the system. So, step one should be all you need.
Any questions, let me know.
Alex H.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I’m getting charged 999 a month for installing Google play the music app and I don’t know how I did that don’t need it I don’t want it how can I remove it or get out of the contract?
von
Will it unsubscribe the app Google play music and not be charged with $9.99 a month
von
Antwort hinzufügen
Nick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 33
Insgesamt: 3,118
