Zum Hauptinhalt wechseln
Die Neuauflage des Apple 13" MacBook Air von April 2014 wurde mit Dual-Core i5 und i7 Prozessoren aufgefrischt. Die Akkulaufzeit wurde etwas verbessert.
283 Fragen Alle anzeigen
No input/output devices recognized
I've had this issue on and off. In the past, it has simply resolved itself randomly. Hoping to find a more permanent solution.
I am unable to use built-in speakers or microphone on my Mac, and when I go to system preferences>sound, no input or output devices appear listed. When I plug headphones into the headphone jack, the computer does not recognize these either. However, when I use Bluetooth headphones this does work.
I spoke with Apple on the phone and they had me reset Pram and try starting in safety mode. Finally stated up in diagnostic mode and got the error VFF001 as a hardware issue. They said I'd have to take it in to an apple store and spend probably hundreds on it, which is a lot for a nearly 7 yo computer.
Since then I've also tried reseting SMC, but no luck.
Heard this may be an I/O board issue. Any thoughts??
Thanks in advance
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It does sound like the Cirrus DAC which is part of the I/O board has failed or the I/O cable is bad.
I would first see if the I/O cable fixes things then go with the I/O board following this guide MacBook Air 13" Anfang 2014 I/O Board austauschen
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Amou wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 50
