OK, very strange! Sounds like the system was very rarely used if at all..
In some ways that helps narrows down is issues.
Let’s check the onboard diagnostic LED’s what are they telling you?
LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
First thing I would do is to replace the PRAM battery as it’s likely dead being unplugged from AC for more than six months would have drained it.
Then the question is what needs replacing beyond the PRAM battery is dependent on what the diagnostics tells us after we replace it.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Lets give this a try, restart your system and press the T key to enter into Target Disk Mode. Do you see the FireWire and ThunderBolt icons on your screen?
Reference: Mac startup key combinations
You'll want to use a USB keyboard.
von Dan
Black screen Dan :(
von Bart
@danj
Hi Dan
So I've opened it up and......... I got SHOCK
NOT A SINGLE piece of dust inside - I've disassembled it completely - it is NEW inside - not a single piece of dust inside radiators - it is shiny inside - warranty stickers on GPU and CPU intact - GPU card is like NEW - not a single piece of dust - inside fans - they NEW - if I had Mac Pro I would check how long that HDD was on but I dont.
Even if someone wold submerge it - still there should be some marks of dust - but NOTHING
Madness
von Bart
