Zum Hauptinhalt wechseln
Die Neuauflage von Apples iPad Air Tablet vom März 2019, das mit dem A12 Bionic Prozessor und dem 10,5" Display antritt.
Can just the glass be replaced?
My LCD is intact and just the glass is broken. Can the glass be replaced and how difficult is it to do if so? I’ve replaced screens and batteries in iphones before.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Air 3 has laminated/fused LCD and digitizer, tools needed to separate and rebond them are not cheap, it’s more economical to buy the screen assembly from a reputable vendor like MobileSentrix/iFixit/InjuredGadgets etc.
War diese Antwort hilfreich?
Bewertung 1
Hi
It is possible but extremely hard to do so what I would do is get the screen off it carefully the find someone who will buy it from you as there are thousands of people who will buy and refurbish those screens ,once you have done that I would put the money from it towards getting a new screen to reinstall and start enjoying your iPad again!
Hopefully I answered your question
If you have any more questions please
Bewertung 1
hello Blake,
air3 has integrated matrix, touch level and glass. Cost is circa 130$ if you can change it yourself. You will need a adhesive gasket (3-4$). That is all. Cost in repair shops is about 200-250$. It is not more difficult than replacing the iPhone, but due to the size it is time consuming.
I hope that I helped, regards,
Bewertung 0
Hello,
The screen is laminated with the display unlike on the entry level iPads with a separate digitizer (glass). If you do a DIY repair you should order a new screen. Unless you a special heating pad and a screen that some repair shops have, you can do a glass only repair. However it is not worth it because it is very difficult and will take several hours also you can break the display to.
Best regards, Drew
iPad Air 3 Screen
This assembly includes the LCD and glass digitizer screen. Bild
Produkt
iPad Air 3 Screen
$199.99
Bewertung 0
Antwort hinzufügen
Blake Butler wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 34
Insgesamt: 3,479
