iPhone 11 pro not included
Hello, the phone is obviously dropped and does not turn on. what is its problem circuit board or battery.
Ist dies eine gute Frage?
If you did have vibrate on mute enabled, you can perform a quick and easy test. Simply flip the mute switch. If it vibrates then its obviously not the battery because it is powered on. You could also try to call your number. If it rings then again, it’s powered on. If you dropped it you most likely damaged the OLED panel.
War diese Antwort hilfreich?
Thanks for the info will work. ;)
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 259
2 Kommentare
have you tried a replacement screen at all?
von Jade Richards
I'm not I thought it was the battery
von dimit1r89
