Zum Hauptinhalt wechseln
Das USB SuperDrive von Apple ist ein externes optisches Laufwerk, das im Wesentlichen ein Rebranding des MacBook Air SuperDrive ist.
35 Fragen Alle anzeigen
Can not find Super Drive in Finder or Disk Utility.
Super Drive was recently plugged into a non apple laptop (did not work). When I tried to use it in my MacBook Air using Satechi Aluminium USB-C Multiport Pro Adapter it says USB Accessory needs power. (It worked before) Can the Super drive be fixed or is it best to just buy a new one??
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It might be repairable! It depends on your skills and getting access to the needed parts.
When you plugged it in to the other systems USB port you some how damaged the logic (I wouldn’t use that systems USB port as it could damage something else)
Here’s a guide which will get you in and access to the logic board Apple USB Super Drive optisches Laufwerk tauschen
Checking the discreet SMT devices is about all you can do unless you can get a parts unit to swap out the logic board.
Otherwise you’ll need to get a replacement drive.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thank you for the quick response. I’ll try this and if it doesn’t work for me I’ll replace it.. Thank you xx
von
Don't forget to accept the answer - Thanks!
von
Antwort hinzufügen
Terene Sinckler wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 305
